I would like to know what's out there for software, in regards to color management, from everyone at signs 101.
Caldera?
Onyx?
SAi?
Etc...
GO!
I just went through trialing Caldera and Onyx Thrive. Initially I was put off by the Caldera Interface, but it worked and Color Profiling is included. Also as one sets up hotfolders they should have less to deal with at the RIP.
Then Onyx Thrive arrived, I found it easier to navigate through the interface included profiles printed great, however I had some scrim banner material that needed more passes and Unidirectional. Onyx sent me a trial key update but told me this was an option extra, would not tell me the price as that was up to my dealer but it sounded like it was going to be over $1000.00 more. I did manage a good profile as well with the Onyx, but I found the Onyx RIP would crash for anything, like 6 times a day or more.
I had mentioned a bit on both here
http://www.signs101.com/forums/showthread.php?112491-Profiling-a-L26500&highlight=ken
I am going to say, be very careful if you download Caldera, do the MD5 check routine that the download is good, make your DVD, then create a iso file back to hard drive in another location if thats able to check out with the MD5 verification then use for the install. I say this as I had some issues when first running Caldera and when I went back and did the 2nd MD5 check the file was different so I burned another DVD and verification ISO file and when it passed I used it to install.
On Caldera generally speaking the factory profiles should look good, if they don't, before creating your own profile reset your printer as per this list
http://otrs.caldera.com/otrs/public.pl?Action=PublicFAQExplorer;CategoryID=13 Topic 100090
The major issue I had with Caldera on the 1st install was after creating my profile, it would test good using my own tiff test image of people, then the same as a pdf would look different - but if I reset my printer as above the test image pdf would look good just like the tif . I have since re-installed with the verified DVD so I may not have the issue any more but just in case it is a bug - resetting the printer after creating a profile is not difficult.
What hardware to use?
In Part to test Onyx I went with the fastest quad core processor Xeon Processor available 3.5 ghz , with 16 Gigs of Parity RAM and both a 256 GIG SSD as well as a Terabyte Seagate Enterprise harddrive. Caldera I had sitting on a separate Terabyte drive. I did need to have a NVIDIA graphics card to allow full monitor resolution and 2 monitors in Caldera or would have been limited to 1280x1024 and 1 monitor. I also had to add a Intel network card for Caldera as the onboard network cards were not yet supported in Caldera Linux.
I did order the Caldera because in day to day use I did not find it crashing vs Onyx Thrive Crashing all the time, yet Windows would keep operating. I also tried Onyx on the SSD but will likely run it standalone on the 7200 rpm Seagate Enterprise drive and move the SSD to a Windows computer where program swaps will make it more worthwhile,
As Onyx sent the program on a USB I had to assume the file was good, but if others have no issues with Onyx Thrive then it could be faulty media.
Unfortunately I have ran into bad install disks on occasion - I went 6 months fighting faulty EFI Fiery disks for instance. It is my opinion all companies should follow the lead of SME Linux from Contribs.org . They include a MD5 check on the ISO so you have the option of verifying the DVD matches the download before installing.
Ken
