Where is the best place to buy a DX4 printhead for our Roland XC54?
Digiprint supplies
last few orders from Digiprint Supplies were total CLUSTER F!@#
in addition one of the heads that was gotten from them had constant nozzle drops and finally died in just a few months after installation. to which they blaimed the inks. which was also bought from them....
maybe others are having good success with them, but we will NOT be ordering anything else
We are sorry to read about your experience. Could you please give us your order number? We will make sure we check this and revert to you about it off line. Customer satisfaction is key to us.
Best regards,
we have replaced the heads on our Roland printers several times.
some of the suppliers were good and some were not so good.
the latest source was Sign-in-China.com - Online Wholesale for AD & Signage Product and their heads have performed flawlessly
on a suggestion point, set up a go pro and record the disassembly process, keep all screws in separate containers and label the order that they were removed,
doing this will make the reassembly MUCH easier as there will always be questions on where all the parts go.
be very careful not to get any fluids/inks onto the heads/cables. ruined a head by dripping some cleaning fluid on the connectors
I would highly recommend sign-in china, as mentioned above. We buy most our our consumable supplies from them, such as dampers, cap tops, wipers, and so on. We've bought many heads from them for our SP-300V's and they work really well without any issues.
Does sign-in china offer sell OEM parts such as the wipers? I only see the aftermarket rubber wipers without the felt back like the OEM wipers which work a heck of a lot better. Also, I have heard the cheap China captops don't last as long as OEM Roland, the foam pad breaks down in them causing issues.
