Where's the grey's???
Discussion in 'Digital Printing' started by TAAG, Feb 1, 2011.
  1. TAAG
    TAAG New Member
    15
    Hello all, New to this great site...
    I use CS5 and VersaWorks with a Roland 540EX model...with 6 colors (C,M,Y,K, Lt. C, Lt. M)
    I use to run a Roland 540SP with just the 4 colors (C,M,Y,K).
    When I bring up my old files the colors are way off??
    Some are in RGB and others in CMYK??
    And the greys are like a GREEN..???
    I have done print samples of greys and I can't get then a good grey.
    Any ideas?
    B
  2. signage
    signage Major Contributor
    9,517
    75
    48
    Oct 5, 2005
    Penn
    Do a search, this has been discussed may times! Hope you understand color management and profiling. Good luck.
  3. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    + on do the search, tired of the "green" talk!
  4. Colin
    Colin Major Contributor
    4,540
    18
    38
    Sep 16, 2004
    Earth
    Are you using the Roland Color Palette System? If not, you should.
  5. TAAG
    TAAG New Member
    15
    I did some research and added the Roland color Palette, and MAN it helps!!
    Thanks!!!
  6. Colin
    4,540
    18
    38
    Sep 16, 2004
    Earth
  7. TAAG
    TAAG New Member
    15
    Colin, thanks. yes that button is checked....
    I posted something on that link you sent....Thanks!!
  8. TAAG
    TAAG New Member
    15
    Is this correct???
    In Illustrator the palette says "Roland Color System Library" is this the one I need??
    It takes away the CMYK bars and it only has 1 bar for the color.....
  9. Colin
    4,540
    18
    38
    Sep 16, 2004
    Earth
    I suppose. The Roland color codes are like "RVW-PR26K"
    Added: You must also print off the entire palette in order to know how it prints on your particular media, and to have a reference.
Similar Threads - Where's grey's
  1. kanini
    4
    770
  2. Biggermens
    22
    1,444
