Why printer and cutter?
Discussion in 'Miscellaneous Print & Cut Systems' started by Kehoe's, Dec 11, 2005.
  1. Kehoe's
    Kehoe's New Member
    18
    Why would a person by two machines rather than one machine with both functions? Like Versa-Camm does the job all at once. John
  2. signage
    signage Major Contributor
    10,699
    291
    83
    Oct 5, 2005
    Penn
    can do two jobs at once!
    If you have a printer/cutter combination you have to wait for the printer to finish before it cuts. With a separate cutter and printer you can be cutting on job while printing another, also if you have something else that needs cut you do not have to wait for the printer to finish.:thumb:
  3. Kehoe's
    Kehoe's New Member
    18
    Once you have printed on the printer how are you able to put it in a different machine to cut and have it cut around the same graphics you just printed? Hope you can understand that sentence? I would think you would waste more time reloading from one machine to another.
  4. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    its called contour cutting,, And, soem of us are not rich enuf to afford a dual machine,,, Or, some of us do not wish to have a dual machine..
    As myself.. i dotn wish to have a dual machine...
  5. jgolo
    jgolo Member
    96
    The printer will put registration marks on the print job and when you load the print onto the cutter, you then send the same job to the cutter, but you only send the cut info.
    Hope this helps.
    John
  6. Kehoe's
    Kehoe's New Member
    18
    Thanks jgolo. Makes more sense now. I have a vinyl cutter now and was looking at a Versa-Camm for later. Have to think if over. Thanks again for your help.
  7. Color Dude
    Color Dude Member
    217
    Go with 2 machines
    Nowadays, you get great deals on 2 machines, most companys will sell you a Printer, Cutter and a Laminator for a real good price. Check out Signwarehouse.com when you get ready. They pretty much will give you the laminators if you buy the printer cutter package. Good deal.
  8. Kehoe's
    Kehoe's New Member
    18
    printer/cutter
    :thankyou: Thanks Color Dude Very heplful info. John
  9. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    ...or you could go with a real sign supply company... & even though they may not give you a laminator.. you would probably want a real laminator anyway.
    I also vote for a seperate printer & cutter. Running both at once happens often enough around my small shop... & if you have a all-in-one machine... you will be unloading & reloading the print before cutting anyway if you will laminate (& your really DO need to plan on laminating a majority of your outdoor printed vinyl)
    God forbid I ever have to ship my printer, but down time can happen, & even on repairs I may do myself, only one machine will be out of commission, not two.
  10. ScottyDoo
    ScottyDoo Member
    297
    Jan 2, 2006
    We have two because we already spent $60K (US) on our solvent printer and have a brand new 64" plotter on our way to replace our dying 48" one. What would be the point of investing in another printer/cutter when what we have already does the job?
    Sure...if we were just starting and looking into it, we would probably buy the hybrid, but we don't do a ton of print/cut anyways, so what we have is perfect.
  11. Scott Reynolds
    Scott Reynolds Active Member
    828
    $60? Gator maybe?
  12. ScottyDoo
    ScottyDoo Member
    297
    Jan 2, 2006
    Yup, it's a gator...DisplayMaker 72s. I have a love/hate reltionship with it.
  13. Scott Reynolds
    828
    Can you explain your "love/hate" relationship with it? Like I said, I have $60k burning a hole in my pocket and Im looking at the 72si, colorpainter, and the Mimaki. Saiko and the Mimaki are both in the same price range with the cutter combo, but the extra speed, cost per sq, and the bulk ink with the 72si might offset the price. Thanks, Scott
  14. Derf
    Derf Very Active Member
    As my service tech said about a print/cut machine.....
    The More moving parts...
    The more to break....
    If //// When the printer breaks I don't want my cutter down with it.
  15. Scott Reynolds
    828
    Very true Derf. And what about the times your running a wrap or a bunch of banners? Print/cut are great if your low volume and your short on space, aka home office. AND, if your doing your print/cut stuff the right way, your laminating BEFORE conture cutting, and you know what that means.
  16. Jackpine
    Jackpine Major Contributor
    Print/Cut
    I had a Roland600 print cut. I ALSO have another cutter for vinyl. Now I have a Mutoh 36" printer and a Graphtec cutter......soooo much better. I looked at the VersaCamm...29.5" print is not all you would need. I print a full 36" banner. Both are good but I very glad I have what I use. SSK have very good prices for packages and the best tech support. SignWharehouse.....NO WAY.
