window perf from inside
bigben
Not a newbie
Hi group,
I've never done this before. What is the more economical way to print and install window perf but inside the window. (graphics facing the window)
I've made some research here but did not find a clear answer.
Thank you.
Ben
HulkSmash
fellers has this new stuff called PANO star or something. I personally don't like it, but it's the only option i know if.
BigfishDM
Print on my non adhesive perf $0.41 a sq.ft and laminte with my inside perf mounting adhesve $0.39 sq.ft
iSign
signlab has a module for printing a perf pattern, or you could make your own, however you would still need white ink print capabilities. Thermal printers have that, but most are not too wide format... some inkjet printers can do this, or a wholesale provider could print a reverse process color image through a "perf" filter, followed by perforated white backing flood coat & then a black finish flood coat
