window perf tip
Discussion in 'Tips & Tricks' started by mark in tx, May 26, 2010.
  1. mark in tx
    mark in tx Very Active Member
    2,081
    Oct 25, 2005
    Harker Heights, Texas
    Put down a thin strip of primer 94 around the outside perimeter of a window, let dry, then apply the perf.
    I have not had any edge curling after I started doing this.
  2. mikey-Oh
    mikey-Oh Very Active Member
    1,431
    1
    36
    Apr 16, 2009
    okc
    thanks mark! have to try that next go
  3. brian oliver
    brian oliver head cheese
    52
    10
    8
    Mar 19, 2007
    ft. collins co
    I'm not familiar with primer 94. Can you enlighten us?
  4. BigfishDM
    BigfishDM Merchant Member
    5,017
    418
    83
    Jun 22, 2009
    All Over
    3M edgeseal around your perf is a great idea also, its like $10 and will guarantee against edge lift also.
  5. coreyb
    coreyb New Member
    22
    Mar 26, 2009
    Chattanooga, TN
    that's how i finish my windows as well. so far no problems here either
  6. mark in tx
    2,081
    Oct 25, 2005
    Bigfish,
    I like the primer 94 better than the edge seal just because it makes less of a visible mess.
    Brian,
    Primer 94 is made by 3M and is available from almost all the suppliers, usually with the "wrap" sections of the catalogs.
  7. JR's
    JR's Very Active Member
    2,904
    105
    63
    Sep 6, 2007
    swansea Ma 02777
    JR
  8. MarioDesign
    MarioDesign Member
    25
    Jun 28, 2010
    Barrie
    +1 on the Primer 94 along window edges! It has worked great for us as well and looks much cleaner than edge sealing tape in my opinion.
  9. timandmikki
    timandmikki Member
    97
    Does it come off the wi.dow easly after the perf is removed?
  10. mark in tx
    2,081
    Oct 25, 2005
    If you can't razor it off, Rapid Remover does the job.
  11. MikePro
    MikePro Major Contributor
    4,976
    235
    63
    Feb 3, 2010
    Racine, WI
    isopropyl alcohol cleans up primer 94, even says it on the label.
  12. Edserv
    Edserv Member
    248
    Feb 22, 2009
    Thanks for a great suggestion! Never thought of using 94 for that but can't wait to try.
  13. WOODBS
    WOODBS Very Active Member
    3,396
    1
    36
    Jun 5, 2007
    disagrre with the 94, unless your using 3m perf...trim back and lam tape it
