window perf tip
mark in tx
Put down a thin strip of primer 94 around the outside perimeter of a window, let dry, then apply the perf.
I have not had any edge curling after I started doing this.
BigfishDM
3M edgeseal around your perf is a great idea also, its like $10 and will guarantee against edge lift also.
mark in tx
Bigfish,
I like the primer 94 better than the edge seal just because it makes less of a visible mess.
Brian,
Primer 94 is made by 3M and is available from almost all the suppliers, usually with the "wrap" sections of the catalogs.
MarioDesign
+1 on the Primer 94 along window edges! It has worked great for us as well and looks much cleaner than edge sealing tape in my opinion.
