Windows XP Service Pack 3
Discussion in 'General Software' started by Shovelhead, May 13, 2008.
  1. w2csa
    w2csa Active Member
    596
    Mar 15, 2008
    Canandaigua. NY
    Downloaded and installed the other day.
    Takes a while but no issues to report.
    Chris
  2. DARLAK
    DARLAK Guest
    my neighbor called me over yesterday,
    he spent the whole day thinking he had a virus because some of his internet functions were not working.
    he removed all his spyware and virus protection trying to fix it.
    he had on automatic updates, SP3 wouldn't install without the XP Professional Office with Frontpage installation disk, which he didn't have...
    he bought the computer at best buy, they gave him a XP home installation disk, but his computer has XP Professional installed on it....
    he's stuck with a half installtion of SP3 and can't get out of it....
  3. Vinylman
    Vinylman Very Active Member
    1,057
    6
    38
    Aug 15, 2005
    Berlin Center, Ohio
    How do you TURN OFF the auto update feature???
    Regards,
    Bob C.
  4. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    be sure you want to make this change. Especially if you have IE7 installed. There are some certain challenges that will crop up that could affect your usage.
    for example..
    IE7 and this update could cause some problems.. But, you cannot rollback IE7 and return to IE6 with out doing certain gyrations....
  5. weaselboogie
    weaselboogie Very Active Member
    3,835
    9
    38
    Apr 23, 2006
    Us
    There's a shield in your task tray. Click on that and select to turn off automatic updates.
    What's annoying is that IT IS STILL THERE reminding you that your automatic updates are not automatic. In that dialog box, on the left hand side is something about settings. In there you can turn off automatic update reminder.
  6. Vinylman
    1,057
    6
    38
    Aug 15, 2005
    Berlin Center, Ohio
    Weaselboogie:
    Thanks for the tip!
    Regards,
    Bob C.
  7. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    Why anyone would want IE7 in the first place....:popcorn:
  8. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    if you don't load service pack 3, what will happen? can you load service packs after that? I'm so not into the tech part of the wonderful world of 'puters.
  9. Marlene
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    :popcorn:popcorn, just saw Shovelhead had some popcorn and I wanted some too!
  10. DOGraphics
    DOGraphics Very Active Member
    2,351
    2
    :popcorn: sounds good
    Thanks for sharing. and have a :beer
  11. Marlene
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    :popcorn::beergood idea
  12. Shovelhead
    10,882
    16
    Popped in coconut oil , of course.
  13. Marlene
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    no, good healthy lard:popcorn:
  14. OldPaint
    OldPaint Major Contributor
    on this computer iam running XP SP1. never installed SP 2 and sure as hell wont install SP3.......
  15. choucove
    choucove Active Member
    809
    I installed SP3 the other day on my XP professional laptop and did not have any problems. I heard rumors that SP3 was causing problems on certain AMD machines, but this was systems coming pre-installed with XP from Dell or HP because they pre-install the same image of XP on computers whether they are AMD or Intel processor systems. The problem with this is there is a certain Intel driver that gets installed on AMD systems and while SP1 and SP2 allowed this Intel driver to work on AMD processors, something with the new SP3 modifies this and requires the correct AMD driver to be installed and not the Intel driver. I haven't heard how HP has been trying to fix this at all, but if you installed XP yourself or have a different brand then you should generally be in the clear from what I hear.
    I haven't noticed much speed increase or performance stability upgrading to SP3, but it has gotten slightly faster at startup.
  16. Shovelhead
    10,882
    16
    Blazing fast start-up here.
  17. choucove
    809
    The reason my startup hasn't gotten much faster is probably just because I need some real deep cleanup on my laptop. I've had this XP install for about two years and I really like doing a reformat every year and a half to two years just to clean up registry, old files, bugs, everything.
  18. DARLAK
    DARLAK Guest
    probably just because i NEVER shut my down....
    247365...........
  19. 3dsignco
    3dsignco Active Member
    949
    1
    Forget SP3 If it ain't broke don't fix it.
    To turn off the annoying Icon in the bottom tray and to disable Auto updates. GOTO
    Start/Setting/Control Panel/Security Panel.
    Windows Security Center will open.
    Now you will see Firewall. (do what you want. We run a Hardware firewall so we turn it off..)
    Automatic Updates. Click button to turn off or go to bottom and Click Automatic Updates and a new window pops up and you will see turn off updates
    Virus Should show On if you have a Antivirus installed.
    Now on the left you will see some text. On the Bottom you see. "Change the way security center alerts me."
    Click on that.
    A new window opens Uncheck all the boxes and click OK.
    Walla No more annoying windows popups on the lower right of your screen.
