Windshield Curve
artists_touch
Hello All,
I'm still pretty new to the sign making arena and have a question. Is there a particular formula or radius that can be used for windshield lettering that compensates for the curve in the windshield? I've done several trucks for our business and also some customer trucks as well. I've played around with cutting the words apart and fiddling with them to fit the curve, also have arced the text a bit, but the lettering always seems distorted. Any advice?
Pam
nashvillesigns
every windshield has a different radius. your best bet is to lay down a half inch stripethe lengh of the shield and measure your new custom curve you just created. Then, do the opposite of that in your graphics progam....
the graphics co
run a tape measure across the windshield corner to corner with the top edge aligned to the top of the corners of the windshield and then measure the distance from the top edge of the tape to the top dead center of the windshield. From there you can make an arch based on your measurements in flexi or illy.
Welcome from way down the other side of the state..............................
d fleming
Place measuring tape from a to b. Next measure distance with ruler from c to d, this is your arc. Bend text to match arc in cutting software.
