winplot
wes70
I have been running my summa d60 on Window 98 for about 6 months. I use Corel and export into Winplot. The other day I went to cut and the message in Winplot came up as " Failed to Open Device Comm1". The plotter was not fully size up the media either. Re-loaded the Summa driver and I think I got the cutter set up again. Now, when I try to open Winplot a message " A required .DDL file, LASERMARKER.DDL was not found. I talked to Summa and they said that Winplot will not work with Windows 98, but I have been using this setup for 6 months with no problems. I plan on upgrading to xp anyways. Just curious to why it just stopped working now? Any info would be greatlt appreciated.
TerryStolmeier
I'd strongly suggest upgrading to XP and possibly a newer version of CorelDraw.
In the meantime... have you tried to reinstall winplot?
oc63rag
I just installed Winplot (downloaded from Summa site) and got this same message when I tried to open it. I'm running XP.
Anyone run into this?
dclet
Perhaps a com driver issue... or setting....have you installed anything recently
besides Winplot, change a setting in the bios???
I would double check com1 settings...
didital_mike
You might have lost the registry entry?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
<o:p> </o:p>
Try to use “Search” for your LASERMARKER.DDL in Windows.<o:p></o:p>
<o:p> </o:p>
Once found, copy the File (Right Click and select Copy from the menu)<o:p></o:p>
<o:p> </o:p>
Copy the File to “C:\Windows\System 32”<o:p></o:p>
<o:p> </o:p>
Once a copy of your dll is there;<o:p></o:p>
<o:p> </o:p>
Click on “Start”, select “Run”<o:p></o:p>
<o:p> </o:p>
Type in the command box:<o:p></o:p>
<o:p> </o:p>
regsvr32.exe LASERMARKER.DDL<o:p></o:p>
<o:p> </o:p>
and click OK.<o:p></o:p>
<o:p> </o:p>
If all is well, windows gives you a massage box.<o:p></o:p>
<o:p> </o:p>
“Your Lasermarker.dll registered successfully”<o:p></o:p>
<o:p> </o:p>
At least windows knows now where to find the Dll library.<o:p></o:p>
<o:p></o:p>
best regards<o:p></o:p>
<o:p></o:p>
Mike<o:p></o:p>
<o:p> </o:p>
imaSIGNr
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
<o:p> </o:p>
<o:p></o:p>
<o:p></o:p>
Mike<o:p></o:p>
<o:p> </o:p>
Mike...just curious...Is your name supposed to read" Digital_Mike ? "
didital_mike
Someone very small (and dear to me) tried to pronounce “Digital”.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
<o:p> </o:p>
Since then it is “didital”..:thumb: <o:p></o:p>
<o:p> </o:p>
Best Regards<o:p></o:p>
<o:p> </o:p>
Mike<o:p></o:p>
