Winter Install of Perf material
copythat
I understand that temp., should be at the very least 56 degrees. If I build a plastic tarp around the outside of windows with a hot air blowers. Will that suffice for applying?
TIA
Sign Up!
ChicagoGraphics
You don't need to go thru all that trouble, just install it, I have done many installs during Chicago winters with no problems, even done some with wet appliction.
copythat
I am still getting request for installs and it's getting cold out. I have material for inside installs, but cost more in labor & material. I just don't want any complains. I also don't use lam!
Sign Up!
