Wiper replacement message
inthesignbiz
SPV540 tells me it's time to replace the wipers.
They've been replaced but the nag message keeps appearing.
How can I reset the message?
petepaz
that has recently started happening with our xc also
our tech guy said it could be the scraper behind the wipres needs to be cleaned or replaced if it's not that it's a sensor. haven't had time to do anything about it yet and it hasn't effected the machine so i will check it out monday
FrankW
The Printer don't check if the Wiper is new or not. Its a counter who can only be resetted with using the regular way to replace wipers through maintenance menu. When replacing the wipers using for example the service modes I/S-menu the counter will not be resetted and the message continues.
SP540V: Switch the Printer on while pressing Cleaning Button. Press the arrow down key one time, Enter, then follow the instructions (without replacing the wipers if new)
Xc540: its in the Sub Menu
