garisimo
Ok, in the same vein as Tips and Tricks, I am going to post my gripes / wish list for the Summa DC4 / DC4 sx, and encourage others to do the same -- hopefully we can compare lists and offer suggestions or workarounds for the little things that drive us to space madness.
(1) Number one on my list is the inability to save different preferences for different types of jobs in ColorControl -- It would be immensely helpful to save presets for specific jobs, just like you can with a desktop printer (envelopes, labels, etc.) -- I would love to be able to select "HMIS Labels" from a drop down and feel confident that Flexcut was on, three color process was selected, and weed box had been checked. This is especially true for Visionprint jobs, where many different setting have to be adjusted in order for the print to be successful.
(2) It would be great to be able to print a multi-page PDF from ColorControl...
(3) Summa includes a Thermal Transfer Ribbon Color Guide with the DC4 printers, which presents actual samples of the spot/process colors available. It also provides a comprehensive DuoSpot Printing guide, with actual print samples of mixed spot colors (i.e. White + Aqua Green = Pastel Blue) -- to achieve this effect it is necessary to have two overlaid objects, each a different spot color, with the top color set to overprint. I would like to see Summa define these colors, just like they defined Contour and Flexcut, so that you could have one object in the design set to the DuoSpot (i.e. DS_PastelBlue) that would prompt the machine to automatically overlay the spots as needed.
(4) They should add a small thermal ribbon (1/4") to the print head that only prints registration marks so you don't have to waste miles of cyan (I have since adjusted the preferences to save ribbon so it only prints on the left and right). I doubt this could be addressed through a firmware update...
(5) Big red button to stop the printing in the case of malfunction (media jam, wrong settings, etc.) -- pause always seems to take a while to engage, and I don't know if hitting the power button is a great idea...
(6) I almost forgot this one, and it is a biggie -- apparently if you create a line (as opposed to a box) and set the color to Flexcut (or Contour, I assume) the printer has a hard time reconciling this with its worldview -- it will attempt to 'close' the line by going over it again, cutting the material twice and causing great havoc (see big red button, above) -- this turns the media into ribbons... I often print multiple labels and would like to be able to make a grid of Flexcut lines that perf so the labels can be positioned right next to each other.
Ok, that's enough for the time being -- got any good ones to share? Got any suggestions for me (and others)? Bring it!
-g-
-g-
Also for your Duotones suggestion, each foil has the "tint" (?) option, i.e. each one has 10 shades, possibly that's why there's no duotone colors. Just an idea........ And.......you said you can print reg. marks on the ends only. Can you explain how, I'd be very interested in knowing!
