GAC05
Quit buggin' me
Hi all,
I need to wrap about 40 brand new ATMs. We just did two for proof of concept approval.
We are doing just sides and a small kick panel in the front.
They have 2 sections
Tops holding the electronics have painted smooth panels - aluminum or maybe sheet metal.
Safe on the bottom looks to be thick cast iron that has a textured painted surface (not too textured kind of like drywall). I cleaned them with soap & water, followed by alcohol rub down.
Wrap goes from bottom to top - top is fine but I am not sure of the safe areas.
I used IJ180c-v3 printed and laminated with 8520 cast mat lam.
It seems ok but the adhesion on the bottom is not as good as the top. I could lift and reset it without too much trouble. It didn't lift on its own and I heat set everything with attention to the edges that I needed to roll in and tuck.
None of them are outside - they will be in the AC and out of the sun & rain.
Samples had to be done in a hurry (overnight of course) so I didn't get much cure time on the prints before laminating or observation time post-install, but everything looked good going up into the delivery truck.
I did get a chance to slap a test piece of laminated Ij180 (not printed) onto the safe a few days before they dropped the units to our shop and it had not curled up but was not too hard to pull off.
Does anyone have experience with these? I'd hate to get to #40 and find out #1 is starting to fall apart.
I can order different material if there is a better choice for these - it just needs to be solvent printable for my Mutoh.
Wayne
Wayne
