altereddezignz
You can do it in layers if you are worried about something lining up. I try to keep overlays minimal because I don't want to have to worry about other pieces when I finish a wrap but overall I think they don't look out of place. And don't assume that vinyl will come off without damaging the wrap.
I have used Bad Wrap templates before. They are good for the most part. I usually design in illustrator and use a bad wrap template/picture of the vehicle as an overlay to see if my template is accurate and make adjustments as needed
I used photoshop b/c the template was designed for photoshop. I am used to illustrator b/c i have always done single color layered vinyl. As you can see from the green at the bottom of my design the tribal type brush has a jagged edge to it i guess b/c of the brush being scaled up. Need to learn template making for illustrator and do most of it there. Some stuff seems easier in photoshop than illustrator and the same the other way around lol.
Guess if your designing for a truck and need to scale it up to put it on a semi trailer illustrator would be perfect but would u still not run into the same issues with the background layers even if designed in illustrator?
