Make sure that when you replaced the cap tops the ink is actually flowing through the waste system. You can take a syringe and hook it up to the tube that comes from the cap top and connects to the pump. If you pull the syringe down with the heads capped and no ink comes out, check the bottom of the head for built up ink that may be breaking the seal between the cap top and head.
