ANAGraph Elite Express 60E - not plotting
Mikistromar
Thanks for answer. I got null modem cable but not work properly.
In plotter is wiring 25F
2-green
3-white
4-red
5-broun
6-8-20 together at
my wire in cable 9F PC - Plotter 25M
9F and 25M
1 - 8
2 - 3
3 - 2
4 - 20
5 - 7
6 - 6
7 - 4
8 - 5
Work when i to mark where to cut, but if send cut/plot nothing work. Only writin to LCD
[PGING:
Tool Toggle: ENTER
But if I press enter - there is nothing like it was plotter a frozen.
I don`t now what is a problem my be cable or mainboard.
Please help me.
Techman
this is a serial to serial system. Use a null modem cable from the serial port on the computer to the port on the cutter. serial and parallel looks alike,, So check to be sure you are plugged ito the serial port.
Mikistromar
Yes i plugg to serial port COM1 to computer and another to db25M to plotter.
And parameter set correctly. Test is ok but not cut. Do you now how is correctly wire this cable.
