ProColorGraphics
Did you purchase from caldera or is there distributers. Thanks
I got mine from Advantage. I did talk with Ben first. He was very helpful. We even did a one-on-one webinar to show me how everything works.
I'm not seeing what I'm looking for in latex printers being asked about. I've read by others that there is less wasted ink compared to solvent, but how often do you guys have to clean the heads and how long can the printer sit without having to worry about clogs? Is the ink transluscent or pretty much opaque to cover the surfrace pretty thickly, covering up a bottom element? how well does it bond with metallic and reflective vinyls and are there any brands that work better than others? How much pull on wrapped elements does it have and does it get spider cracks in the ink when pulled around compound curves?
Prints on metallics perfectly. Your only problem is going to be the cut perameters. Our 56" Graphtec doesn't always see the peramters on metallic. Too much reflection.
with the discussion going toward ease of use, ...knowing that the printhead is easy to replace, i was curious out much one cost. so i googled it. $110.00!!! that is insane. surely hp knows the market will bare a higher price. that's a huge advantage compared to us piezo guys sticking with $2000 in heads even though the heads need replacing but cost too much to keep popping in like consumables.
Yeah but, they suggest you replace print heads every 2-3 cartridges of ink...............so adds up kinda fast.
buy a 2nd loading core for about $200 and reduce downtime
I am strongly thinking about putting in for an additional one as well. The shop that demoed the printer for us was also looking into it too.Is that all those cost? That's not a bad idea at all!!![]()
Just got our installation pushed back till Tuesday.
