calculate remainder of roll
bpp
Is there a way to calculate the remainder of a roll. I have a partial 13oz vinyl banner and want to send to print how many banners that I can fit on there. Is there a way to calculate that?
heyskull
It is not just figuring out how much is left on the roll, but how much was on it when you first used it.
I have had loads of print rolls that had a lot less on them than they should have.
I have been short by over 7.5 Metres on a 50 Metre Roll!!!!
SC
bpp
Thanks. Tried ChatGPT to figure out the formula and they threw me all over the place. I will try these
Boudica
I write on the media how much is left before I take it out of the printer.
When that doesn't happen, and I need to figure out how much is left I use a digital caliper and math.
Here is a link to my math/formula
Stacey K
I like making signs
I like to live on the wild side. I don't usually print over 4' or 8' at a time so I unroll it on my counter and make sure I have enough. Last week I looked behind me at the printer and saw cardboard! I quick used a razor to cut it off the roll and it worked out perfectly!
Geneva Olson
Expert Storyteller
you showed me this long ago. I keep meaning to buy a digital caliper.
productionMike
Head babysitter, nappy changer and bottle washer!
MOST SATISFYING ISN'T IT!:)
JSIGN
Not super accurate - but works pretty well and easy to do - if you have a 3" core, then roughly every layer you can count should be approx. 1 foot ( based on PI )
Boudica
This is kind of interesting.... I just now needed to figure out if I have enough on a scrap roll of poster paper to print a template.
I pulled out my calipers and used my method... I came up with 9 feet.
For fun, I thought I would try Fire Sprints calculator, and it came out to about 18 feet - twice as much.
Then I tried Stacey's method and rolled it out on the table to measure it - it's about 11 feet.
Stacey K
I like making signs
It would appear that your method is the safe method. Using my method is OK for small rolls like this but larger rolls, your method would be more accurate and safe than Fire Sprints, and faster than mine.
Great investigative work!
Boudica
I should note that generally, I'll subtract 3ft from what I get just for extra cushion - I didn't in this experiment though.
FireSprint.com
Trade Only Screen & Digital Sign Printing
The problem with using a caliper measurement like the way we present in our calculator, is that all the inputs need to be very accurate.
The math checks out, but if you get off by a few mils, then it can throw a roll length way off.
Boudica
Is there a way to change your calculator to mm? In my method I use mm, but your calculator was inches, could by why it wasn't as accurate?
Fechin
Signs around Chicago
On my more heavily used rolls, I usually keep a little piece of masking tape on there with the amount written. Load a new one with 150', stop for the day at 112", write it down. Then as you go you start to see how much is left on others.
productionMike
Our EPSON S8060 has a roll Length counter as long as you input the roll length when first loading the media roll, its fairly accurate.
I have to preface by saying the Epson takes about 12"-18" of media for make ready before sending to print.
Not sure if that is taken into account as the printer tracks usage.
