Caldera Help
Stella_FB700
Trying to print a spot color of white in caldera V9
File is set up as a PDF with "spot color -white" CMYK
Its printing a full flood of white and not the shapes created.
Any help would be appreciated.
C
ColoPrinthead
Guest
Their is an option to specify what white you want, spot, underflood, and over flood. IIRC it's under one of the tabs from you image window/panel.
Stella_FB700
I have everything set up - please see picture. Just for some reason its printing solid and not the actual shapes.
C
ColoPrinthead
Guest
I would call their support line and have one of their people log onto your RIP and take a look. I don't know if they have a number for Canada but in the US it is 612-216-5212
ProColorGraphics
I have never had that issue and curious as to what the problem is? Also, I don't think V9 is supported any longer either if I remember right.
Stella_FB700
Turns out i have V10 - didn't think i upgraded.
But the issue was basically using the white mode i needed to use the print mode "photo" and nothing else.
Everything else registered into the system.
"Had a idiot moment - just had to play with the settings - haha"
