Doyle
This is the job from hell that will not go away. The fender/wheel well areas on this van have been giving me trouble. There is a recessed area about 1/2" or so deep and I CANNOT get my material to stay put in these areas. It keeps popping back up in the form of bubbles, some small, some very large.
I have tried many things to fix this. To start with, the material we used for the van was orajet 3551ra. I know this was probably not the best choice of material for this job, but we have used it on similar jobs many times without any trouble. After these areas of vinyl kept popping back up, the first thing I tried was adhesive primer in these areas and replaced the graphic. This did not work, the same problem was occuring. Next, I tried reprinting these panels with Orajet 3951ra and thought for sure that this was the problem. I removed the failed panels, removed all adhesive, cleaned with rapid tac (we use this as a cleaner, but wipe it all away, applied dry), then prepped the area with isopropyl alcohol. The surface was cleaned very well, free of any oils or contaminates.
I reapplied these panels AGAIN. I went over the recesses lightly, waiting until I was finished to go back and sink the vinyl into the grooves. I heated the vinyl, and slowly worked the vinyl into the groove, about 1/8" at a time, working the air towards one end so it could escape. Everything looked great, the vinyl was holding down into these areas perfectly, until I came back to the shop this morning to see they had all started popping back out again. By this time I was furious and I started heating it up again and repeating the process of working the vinyl into the recess, but it didn't seem to adhere as well this time. And in some areas, I actually noticed moisture escaping the bubbled areas through the small holes I pierced to release the air. I cannot figure out where this moisture would have come from, since there were no open areas at the edges of the vinyl to even let water in, so I am really confused now.
After going back over everything again, it looks like a lost cause. The vinyl is still not staying in the grooves, and now the areas I have heated up are starting to show fading from the heat. I would appreciate any pointers that anyone has for me because I am at my wits end with this van and I just want this job to go away, even if it means reprinting these pieces again, I just need to figure out where I am going wrong. Thanks in advance!
