HulkSmash
PRIMER 94 PRIMER94 PRIMER94 and heat and roll youll have to work it shouldnt be a problem tho.
Aaron, have you even read this thread? He's using oracal. Primer94 has a negative reaction to any oracal adhesive...
Bondo and hot glue to expensive.
We like to use the backing paper off the wrap so we get the most bang for our buck here. Just keep folding it up till the void is semi flush.
FYI....from Rapid tac's site, and every one of their bottles:
Detailed Use Instructions
STEP 1. Clean surface thoroughly with Rapid Tac and a kitchen paper towel. DO NOT USE OTHER CLEANERS OR SOLVENTS. (We do recommend Rapid Prep as a pre-cleaner for surfaces that may have been exposed to wax, silicone, or other suspected contaminants)
inexperience....
Chevy Express van. The recess above the front and rear fenders never stick long term. Doesn't matter if you use IJ-180, it will not stick long term.
We use Avery 1005 EZRS and their 1.3 lam. I'll tent those channels all day long with no glue. Heat the area and push it in. Post heat to 200* and they'll never come up. Ever!
