Careful with solventinkjet.com
DL Signs
Never go against the family
Hello, and welcome to the internet.
The place that took away common sense approaches to solving problems, like working with vendors and service providers to remedy problems. Instead, everyone wants to come bash first to anyone that will listen, then wonder why no one wants to deal with them, and why problems don't get resolved.
When you deal with sensitive electronics and want to take the DIY approach, you risk everything. There is no un-do button, and something as simple as a solitary drop of ink in the wrong place, a cable not seated properly, not completely disconnecting power and waiting for capacitors to discharge, and a long list of other things can do a lot of damage. Not following the proper procedures in order... Perhaps you should have gotten a tech to do it in the first place, yes you can save a few bucks doing it yourself, but you also inherit the risk and liability.
Texas_Signmaker
Very Active Signmaker
So here is the timeline..
Mar 16th - Firefighter tried unsuccessfully to change the head.
Mar 21st - He has a tech come out who didn't know what he was doing and spilled ink everywhere and "left the printer more broken then before" and the lead tech agrees to come out later.
Mar 21st - You immediately get on here and create a thread complaining about the tech company.
Mar 24th - The lead tech comes and says you were sold the wrong head and blames the company you bought it from. (No bias there right?)
Mar 24th - You immediately get on here and create a thread complaining about solvent inkjet
Thanks that is exactly the problem. I’m not trying to bash anyone if I don’t have a true reason to. They sold me a print head and confirmed it was for my printer and turns out they were wrong in fact and they admitted it after they talked with mutoh. The problem is if I do a head swap like I did multiple times in Roland printers and Mimaki printers with no issues at all. The problem lays with they advertised something and it was incorrect and in return it cost me thousands of dollars to fix. Yes I am under pressure when you have a lot of customers waiting on their stuff and you have to explain to them what happened and start giving refunds or out sourcing printing. That gives a bad name to my business 100 percent and ruins trust with customers and I don’t like it. People can bash me on here all they want but if they were in the same situation they would do the same thing.
I still dont believe in any way that a wrong part numbered DX7 head had anything to do with frying something. The only possibility is that maybe the new replacement head (unlikely but defective new parts can happen) was defective in some way - just being the wrong part number will not fry anything, a wrong part numbered one just might not work as expected such as solvent ink might melt an aqueous manifold or it it might have gaps or distortion in printing due to encryption. The only way something gets fried replacing a head is either a defective part, ribbon cable damaged and shorted, ink leaked onto the heads board, static damages, or some other part was already fried.
agreed, we have swapped out all flavors of DX7
change manifold if they are aqueous, but,THAT PORTION OF THE ELECTRONICS is all the same
encryption (or lack of it) may differ, but no differencee that damage the output/driver circuit that sends signal to printhead
bcxprint420
Sign & Banner Xpress
I will give my two cents. Those heads are very much interchangable and the head change alone would not fry your board. The original tech sounds like to me did the damage however it is just as possible you did the damage originally but my bet is on the ink getting all over that did any major damage. However the best you can hope for is the service company sllitting the cost because there is no proof it was them and none that it was you. What is pretty definite is the head vendor did not fry your board. The worst they did was sell a incorrect part that is the correct part minus software which will not fry a board. I understand your frustration but being called a dick by a member here is just as out of line here as anything else so ignore that part but focus your attention on the solution because no matter what tomorrow will come and if you have running equipment you can move forward knowing you will make more money and if you handle this professionally you will eventually end up ahead along with everyone else. Or we can follow the other path and call each other dickheads and see where that leads us. I think you see the point. Most times its win win or lose lose its rarely win lose if things are handled professionally.
unmateria
Hi guys... This thread should be deleted or at least change the title. Its clearly that this mess has no relation with solverinkjet and is going to damage their solid reputation because a customer with a wannabe-tech (not from solventinkjet) has destroyed their plotter.
Sorry, but if u discharged tubes ink over a printhead, a motherboard and a crboard without properly cleaning and drying it it before turning on the machine again, you are going to burn it. Its a shame, I know, but go to ask for responsabilities to the real responsible (you know who is him)
Medina Signs
Old Member
The reason this thread caught my attention was that as titled, I thought there may be a problem with Solvent InkJet being a ripoff company - I'm glad I read the entire thread and have come to the conclusion that the next time I need parts I will very likely call them first. The last time I had to replace a head, I called the Roland Tech. I hated paying the price, but this printer has worked great many years now. I also know that had I attempted the repair myself the results may have been a disaster.
Firefighter seems to think that advertising his problem and accusing others will get him some free parts. You know, the squeaky wheel.
Verdict - Solvent Inkjet, Winner! - Firefighter, Loser!
Hope you get your printer up soon.
in the last several months, i bought a dx7 & i believe 3 dx4's
vanderj has been an incredible help (with lots of things that i was not buying from him, as well)
everything ships when promised.
i am always a little nervous with the "friday curse (you order something late thursday & it is supposed to ship so you have it on friday (we have a tech MUCH YOUNGER THAN MYSELF,
who can perform some alignments that just exceed my abilities these days, & he is mostly available on saturday and sunday)
fundyfresh
Excuse me??? This printer worked 100 percent before the print head test unfortunately the head was missing nozzles and cleaning didn’t help so of course I ordered a new print head. Placed the new head in and hooked it up just like it was before and boom I got the head heat error. Honestly at this point I’m just worn out. When you have a printer and already behind and have to work your butt off to keep up you expect the head on their website to be correct I even confirmed it with them before purchase. The problem lays that I’m out thousands upon thousands in parts techs and down time. Yes I understand but when you leave them emails also their chat and a voicemail and they still don’t get to you it’s quite frustrating. Because now I have to sit until Monday just to hear back from them. I understand completely mistakes happen we are all human but if your going to advertise a head for this model printer and confirm it’s for that and then they send it to you and you install it because you think it’s the correct head and have this issue pop up where or fries your main board of course I’m going to be upset. I’m not a big shop I’m a one man operation and I think we both know some customers have zero patience’s. Their head was listed at 1800 now they are quoting me 3k. So that would be over 5k I spent this week in parts alone. If I screw up a customers job I can’t just tell them all well deal with it no I make it right and chaulk it up as a loss and make it learning experience.
I'm dealing with this right now. Mutoh 1641sr. Printer was in complete working order except the magenta was toast. Ordered a new printhead from solventinkjet. Put that in, got halfway through a test print and got a head temp error. After that the whole machine shuts off went it starts to try and print. They recommended new cables. So I did cables and new fuses just to be sure. Same problem. Had a tech come by today and said everything is good, but the new print head is bad and tested new and old fuses and all were still good.
Smoke_Jaguar
New cables are always recommended as those flat flexy bastards are so easy to damage and short out connections. Temp errors when the head isn't overheating are usually caused by shorted thermistor circuits in my experience. If you toast the circuit, the whole head isn't easily repairable. When buying a head, ask about warranty conditions. Lots of vendors require cables and dampers to be replaced for any real shot at warrantying a head out. Heads are fragile little buggers, and even professional techs can blow them up more often than they want to admit. The margins are also poor, so a vendor having to warranty one might mean they need to sell 10+ more to make up the loss.
i've ordered half a dozen heads from solventinkjet in the past & every single one worked perfectly.
+1 to replacing ribbon cables & dampers while you're at it, its a cheap addition to an expensive process and bending/flexing them (especially older ones) will cause failure to comms.
+1 to many things could go wrong during service of these machines, and a tech is only as good as knowledge of the timeline of events. diagnosis&service is a pita, especially when something else inadvertantly breaks along the way.
super jealous of the youtube vids now available to explain most of these processes nowadays, because when I first got into DIY service this forum was my only savior.
Smoke_Jaguar
As a guy who DIYs everything, I also understand the risks. Simple fact of the matter, when installing an expensive and fragile part, experience is something that can be well worth the cost.
unmateria
No more questions lol
I was always under the assumption that these heads are all the same for the most part. There are quite a few posts here with people that fried their heads while changing them out though.
Gg
any repair like this (like almost everything in real life) is done at your own risk)
whichever of you people who has never f**ked up a machine in the process of trying to fix it should get a medal.
