Signed Out
dewalt xrp works great we just get 4 packs of bits as they get dull after some use.
Never used a hilti. I have used a dewalt hammer drill and a I own one of these.
I ran a bunch of conduit for our machines last year. Like I said before, everything here (including the ceilings) is precast concrete. The first 5 holes with my hammer drill took longer than the next 50 with the SDS Rotary Hammer. That's not an exaggeration.
The funny thing is is that I didn't know what and SDS type bit was before a friend told me about it, so I was actually using one in my 1/2" chuck dewalt hammer driller. This proved to me that it's not just the bit.
I could not tell you why they work so much better, but they do. The Bulldog doesn't kick any more, in fact it's probably easier to hold than a hammer drill. You don't hardly have to push at all. The tool does all the work.
Ok, I'm done selling now.![]()
That's funny, because an SDS bit can be difficult to chuck up in a standard chuck...usually the chuck teeth will wind up in the grooves of the SDS bit and the bit will be off center.
Thanks for all the suggestions folks.
For me - 1/2" hole is the biggest I'll ever need to drill. I don't do installs outside of flat panel and unlit stuff - and nothing I can't reach with a ladder (I have no bucket, and no intention of getting one). Sounds like Milwaukee or DeWalt will do the trick for me. Now, should I spring for the Rotary Hammer, or just stick with a hammer? Toughest thing I'll be drilling into is Brick or concrete/cinder block.
You're 100% correct - it wouldn't do that great with that size hole.
My post was in relation to the Gary's original question. He's looking to mount framing. I doubt he's using 3/4" or 7/8" fasteners. I was simply suggesting a tool fit for his particular need, not suggesting it as the end-all-be-all, replaces all other SDS drills.
The cordless version isn't designed or meant for 3/4" or 7/8" holes. The DeWalt is recommended for up to ½" holes. The Hilti 22V cordless is recommended for just under ½" holes. Anything over that is getting into corded territory.
a simple solution is to pre bore hole with a 3/16 bit followed by a 1/2 inch and then a 3/4 if u have a under powered tool. just a suggestion no offense please.![]()
