CS3 Install Problems
nversestudios
Wow, I purchased CS3 Web Premium and have not been able to install it on my Dell (XP Pro, sp2 updated) workstation. I have spent over 15 hrs. on the phone with the techs. from Adobe and still no go. This has been going on since the 10th.
They are trying but not as of yet, they have escalated it to "level 2" what ever that is. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
<o:p></o:p>
Anyway I was wondering if anyone had similar experience or it was just me.<o:p></o:p>
<o:p></o:p>
Thanks<o:p></o:p>
nversestudios
Gets acrobat 8, common files loaded then terminates install showing the 2 items loaded correctly with green check marks next to them and then below in another section of the screen it shows all other elements with red X next to all other 9 items. These 2 items take about 14 min. to load then termination.
As far as reformating, I am not sure if you were serious but not an option at this time.
nversestudios
Yes, we did run this and used some CS3 clean level 4 and Microsoft 3.1 install software to make sure every thing was clean. Also using the system config utility to use selective startup.
odecom
sounds like it might actually be an error in the disc that you got in your package. it can happen. you might want to try to get them to send you a new one to see if that does any better.
Replicator
also make sure and shut-down all non essential programs that are running,
as these may interfere with the install. although at this point I tend to agree
with odecom, probably a bad disc . . . !
nversestudios
Thanks for the tips, I will make sure nothing is running or loaded that dose not have to be.
Got a call from an Adobe tech today wanting me to try and copy application DVD to hard drive and install from there. Trying it as I write this, I guess I will see shortly if it worked. They are scheduled to call me tomorrw in the AM.
GK
do you have any internet security/firewall/anti-virus software running? I had to disable ad-aware and kaspersky internet security on mine to get it running to install. have you tried cleaning out your registry files for your adobe products? there could be some bad reg keys in there that won't allow you to continue your install. Have you tried installing the applications one at a time instead of just one large install?
nversestudios
George,
Thanks for the tips, yes on the firewall/spieware approach and cleaning up any old Adobe items in Reg. files. I will take a stab at the single application install (did not try this one yet).
Thanks again!
Tony Teveris
The CS3 installer is new, Adobe hoping to clean things up with DLLs overlapping with different suites, etc. Durningthe "beta" run I found / had a number of install probelms with PS and AI, all reported. I did not have the Web design application. The adobe install sits on top of MSI (Microsoft Install logic).
I need to test the "Master Collection" I just got the other day to test it's install. This is the grand daddy of all the suites on a DVD.
nversestudios
Is there a way to not use the CS3 installer and just launch the applicatons for install. When I asked the techs about this they said you could on Acrobat but the rest of the apps needed to install through the installer as you could only use the CS3 suite serial # not individual numbers to activate the apps. Not sure if this makes any sense.
Checkers
I would lean towards the bad disk or corrupted files on the disk too.
However, this is exactly why I don't try to even keep up with the "latest & greatest". Why should I pay for a retail price for product only to be another "beta tester"?
I don't upgrade any design software until the programmers introduce their service pack. With the new Windoz, I think I'll be waiting for SP 3 :)
Checkers
nversestudios
No progress from this AM they had suggested that I uninstall any Google desktop features I may have had as this is a know conflict for CS3 install. I did it and no go, now at a "level 3" escalation.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
odecom
tell them to screw level 3 and either fix it now or give you your money back or at LEAST offer a free upgrade to the design premium...
i feel ya man, this must be getting to be just a big long joke for you :(
Techman
did u try the CS3 cleaner?
they have a cleaner out for fixing some problems. Especially if you had the beta installed..
