Cutter Skips Letter When Cutting!
wildhock
Hello All,
Here is the problem I am having. This weekend I was cutting some basic VIN and DOT numbers for a trucking company. Design and cutting was done out of Illustrator to my GX-24. On one line of text/numbers, the cutter would not cut one letter in the line. I printed it on a ink jet and it printed fine. I tried outlining all of the text and it still skipped the same letter. Anyone had something like this happen and have any suggestions?
Thanks,
Jon
511graphix
check the color of the font if its in a diffrent shade of black it well see it as a different outline..so select all text and change it all at once to one color
bighun
511 is right. But, If that doesn't work, try rubbing your belly and patting your head while clicking send with your mouse using your right elbow.
Techman
or get cocut pro and corel and never have that problem again. Cocut will not allow you to cut a bad graphic.
Jackpine
Try converting the text to curves and combine them. Then send as an eps.
Hello All,
Thanks,
Jon
