Cutting aluminum composite boards
CP Signs
Alright,,,so no matter how long you've been doing this, there is always room to learn. Sometimes it looks too simple. Cutting DiBond / Alupanel / TrueStock or whatever brand you use is a messy job. That black core sticks to everything and the place gets really messy. So one day I'm talking with my buddy who's been doing this for 2 years or something like that and asks; why not cut it with your utility knife? I had that ,,,deer in headlights look on my face, so I grabbed a piece, tried it and couldn't believe how easy it was. NO mess, clean cuts. What I like most about it is sometimes your graphics are on and you have to make a cut without scratching it,,,this way is very simple. Here is a link of a quick ( a few seconds ) to show how easy it is.
http://www.youtube.com/watch?v=XcjjoOXHISs&feature=youtu.be
J Hill Designs
wow I just tried the single swipe trick as seen on video. IT WORKS!!
thanks
before I had always done line at least 5 or 6 passes
J Hill Designs
yeah no photo. but yeah, I used a standard stanley utility knife with cobalt blade (just what is in the knife right now) nothing special
Salmoneye
Palm slaps face. I didn't know. I just tried a few pieces, worked great but it did ever so slightly bend the sheets, the acm I use often is less expensive 3mm stuff.
gabagoo
I use this too, Even makes clean cuts after I mount the adhesive, then I nip off the sharp corner with a corner rounder.
what kind of corner rounder? I be to afraid to try mine.
mpn
You can use that corner rounder if you want, no problem.
1/2 inch die in mine
gabagoo
yea I tried not only cutting the composite but the corner rounder too....sweet.... save a lot of time and no more imitation rat poop all over
