Hi, I have a Roland Stika SX-15. I bought it almost new a few years back and it’s had a problem ever since which I’ve never got chance to rectify.
Basically the cutter is fine in the central part of the unit but for about 1.5in on the left and about 6in on the right it just won’t cut as deep. If you extend the blade so it does cut deep enough then the middle section is cut too deeply.
I thought the machine might be bent slightly but that does seem unlikely. Has anyone here experienced a similar problem with a Stika or other cutter? If so what was wrong with it and can it be fixed?
Many thanks for your help, I’ve wasted too much vinyl because of this problem!
Cheers Ian
Cheers Ian
