and if i pick a color in photoshop i keep an eye on the CMYK values to get an idea of if my yellows will have cyan in them or reds might look too orange. photoshops color picker displays LAB, RGD,CMYK and HSB values even when you are in RGB mode.
So then i'd guess you are not applying an output profile in your RIP? If you are, the "purity" of your solid colors will be determined by the ICC in the media profile and the Photoshop numbers are not really relevant.
This thread prompted me to experiment a little with RGB vs. CMYK files. So tonight I printed my Pantone swatch file 4 times. Twice as a vector file, one RGB and 1 CMYK, and twice as a raster file, again one RGB and one CMYK. Both have the output profile of relative colormetric. The file was originally an Illustrator .eps file. To rasterize it I simply opened the .eps in Photoshop. No other adjustments were made
All four were dead on identical. There was absolutely no color shift between any of them. In fact, I couldn't tell which one was which, I forgot to note on each file which was vector and raster and CMYK and RGB.
This sounds like a stupid question, but what does this mean? I assume it means we're doing something right to manage our color. Am I also safe to assume that I'm just as well off designing everything in CMYK as RGB, since I do have a much firmer grasp on CMYK color manipulation vs. RGB?
If your goal is to use all the colors you can capture when you output your files, the role of the working space is important. However, it should be clear that a very large gamut working space isn’t automatically the best option for all situations or something you can “set and forget.”
I am wondering how you printed the Pantone vector swatch as RGB?
Did you convert each patch individually to RGB?
Just asking coz that's how I would have to do it in my sign proggy and if I did it would alter each color significantly.
And if you didn't, then maybe the files were actually the same when printed??
The easiest way to accomplish this would be to open the vector file in photoshop as an RGB file. The spot LAB data will convert to RGB during the rasterization process.
Pick pantone spots you know you can't hit and then change them to Process RGB.
Oh yeah, just rasterize the whole page and save as a tiff.
I suppose I could do that in my sign program too - convert to bitmap. Photoshop would handle it better though and like Eye4clr says you could assign different profiles if you wanted to test them.
I thought Insignia may have had a way of converting the CMYK vectors into RGB vectors en masse.
I'm about to print out my CMYK Pantone chart again and would like to be able to print it as RGB vectors too.
Anyone know of an RGB Pantone chart?
Interested in learning more about Process RGB.
