digital printing on aluminium composite material (dibond, valubond, etc)
Discussion in 'Digital Printing' started by Terence, Jan 15, 2013.
  1. Terence
    Terence New Member
    3
    I run an OCE Arizona 350XT flatbed printer and have had one heck of a time printing on aluminium composite material. After gently peeling away the protective film that the material is covered with, I still get "chatter marks" or light spots in the print. I have tried every chemical I can think of to clean the surface as well. 99% alcohol, 91% alcohol, mask-off & windex, just to name a few. The streaks and spots are driving me nuts!!!! Help!!!
  2. Gino
    Gino Premium Subscriber
    33,545
    2,415
    113
    Jun 7, 2006
    PA
    Welcome from PA..........................
  3. petepaz
    petepaz Major Contributor
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    welcome
    i run that stuff through my roland lej640 with no problems. after i peel the mask i wipe with rubbing alcohol and then print (not sure how durable it is outdoors ..yet...i just made some job signs for a friend so i will soon find out)
  4. LarryB
    LarryB Member
    280
    18
    18
    Dec 3, 2006
    Webster, Texas
    Try using an empty material core and tape it up to the protective film and roll it into the core.
  5. Aklaim
    Aklaim Member
    227
    Sep 8, 2010
    San Jose, Ca
    Check your lamp settings. Sounds like you have the lamps too high.
  6. StarSign
    StarSign Active Member
    650
    75
    28
    Sep 20, 2011
    Southern Utah
    Is it usually just lighter colors?
  7. Terence
    Terence New Member
    3
    Adhesion is not the problem. And it happens with all colors, light and dark.
  8. LarryB
    LarryB Member
    280
    18
    18
    Dec 3, 2006
    Webster, Texas
    The chatter and streak marks are likely from when you were removing the protective liner. Try taking the liner off with an empty core and see how it prints afterwards. When I had a Gerber Ion this was the only way I could get dibond to print without the streaks.
  9. Terence
    Terence New Member
    3
    Tried rolling onto core as well, still get the streaks :(
  10. Grizzly
    Grizzly Member
    185
    20
    18
    Sep 1, 2010
    Utah
    Agfa 1224 hdc
    I have issues sometimes too with light colors showing streaks, especially if i don't pull the covering off evenly. We've been printing on on covered Masonite and the only way we have figured out how to remedy the streaking is to have one person wipe with a soaked lacquer thinner rag and one person behind to dry. This is a little trickier on aluminum though, but it can work if it is a last resort. When you wipe with the alcohol, does it show the rag streaks? I guess you could try to have someone dry right behind you and see if that gets you any results. I wish the inks would cover like they used to. On my Jeti 3150, we could sand and lacquer thinner and alcohol just about anything and it would only show if it was an extremely light color like under 25% ink.
