That will depend on the model printer. What printer are you using? For the 1204, 1304,1604 and 1614, I found these instructions:سلام
I bought new ink and the ink still says . Ink end
Who can help me ?
Mutoh 426ufThat will depend on the model printer. What printer are you using? For the 1204, 1304,1604 and 1614, I found these instructions:
Instruction & process for ink level reset on Mutoh VJ 1204, 1304, 1604 and 1614
This instructional video is showing how to reset the ink level back to 100% for generic smart cards. Check existing Ink Status: _ _ _ _Turn off machineHold left, down right key and power onYou see:…premiercolour.wordpress.com
Could you send the instructions to me? Maybe the same.That will depend on the model printer. What printer are you using? For the 1204, 1304,1604 and 1614, I found these instructions:
I think the printer needs an update. I can not separate to disable the chip feature to use other inks.Explain more about new ink. What ink type? What is printer’s firmware?
I remember old ink labeled as LUH, new ink is UH21. Maybe, you just need to upgrade printer’s firmware for make it possible to install new ink type.
Hi Deari can unlocked any mutoh model even new model, no more smart cards no more ink level hit pm
Mutoh does not sell ink chip cards separately.Good afternoon, colleagues.
Maybe someone can help, we have a Mouton 426 UV printer, but we can’t find an UH 21 ink chip on it to use other inks.
Maybe someone knows who sells or helps to chip the printer.
Thanks in advance for your replies
need this infoGot the printer unlocked, Now my printer can print without any cards at all. Honestly best investment I've done for my printer. If anyone needs help let me know![]()
Can you let me know if you find this information? I Need this as well.need this info
everyone seems to have the unlock...but no good contacts.....Can you let me know if you find this information? I Need this as well.
Helltown concepts I'm not 100% but if this is something you would want to try, I believe it would be the heater control board you would want. I replaced a main board on a machine that had the cards turned off and they still were turned off after the procedure so the main board didn't seem to have anything to do with it. Since the firmware on the heater control board handles the ink cards, my best guess would be that's the board you need. My only concern would be if the unlocked firmware on the heater control board needs to verify anything like serial number and model with the main board, it might fail and not let you use it. That's just a guess though. Might be worth a shot.I have a used VJ-1324 that has been unlocked. Basically want it gone. Maybe the boards will work with your printer?
Hello, I'm interested in having my Mutoh unlocked. I just purchased a large supply of inks and they came without the ink cards. My printer is a Mutoh Xpert Jet 1641SRi can unlocked any mutoh model even new model, no more smart cards no more ink level hit pm
