file not embeded in illy - what to do?
Discussion in 'Adobe' started by Sign_Boy, Aug 23, 2011.
  1. Sign_Boy
    Sign_Boy Major Contributor
    6,429
    8
    38
    May 18, 2007
    USA
    Hey all,
    I'm hoping someone could help me out here.
    I have an ai that's missing an image (it's not embeded) and I don't have the file, I can get it but wanted to try a workaround first.
    I do however have a pdf with the image in it.
    Is there anyway to open the pdf in illy and somehow preserve the image?
    I'd appreciate any help on this.
    :thankyou:
    :supersmilie:
  2. WildWestDesigns
    WildWestDesigns Major Contributor
    6,534
    322
    83
    Sep 27, 2010
    Mid TN
    Did you try "placing" the pdf in an ai document? "Placing" instead of flat out opening seems to be a workaround that's being used lately. Give that a try if you haven't already.
  3. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    Tried it, no luck. It brought it in but I couldn't break it apart.
    Thanks anyway!!
  4. Mason
    Mason Very Active Member
    2,037
    Aug 11, 2005
    Boston
    There is no work around for what you are asking.... bottom line. get the file.
  5. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    Had a feeling, eh it was worth a shot.
  6. Custom_Grafx
    Custom_Grafx Very Active Member
    1,637
    2
    Right click on the Ai file in question, and open with acrobat pro.
    If you see the image there, let me know.
    Sometimes you can see it when opening it with acrobat, but when opening in Ai, it'll tell you it's missing a linked file.
    If it's the former, there is a work around, as WWD mentioned.
  7. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    Did it and it's there
  8. GAC05
    GAC05 Major Contributor
    5,915
    787
    113
    Dec 27, 2005
    Guam USA
    can you post the pdf?
    There is almost always a way to extract images from pdfs.
    wayne k
    guam usa
  9. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    Not sure if the customer wants this out there.
    I'll PM you in a sec.
    On a side note the customer is getting me the file I need.
    Now it's just a matter of trying to figure a way to do this, but I feel Mason may be right.
  10. royster13
    royster13 Very Active Member
    1,817
    2
    38
    Apr 3, 2009
    Montrose BC
    Drag it in and put it back together....Cut and paste it into a new document....And then rasterize the result....
  11. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    Thanks, but that's not working either.
  12. MikePro
    MikePro Major Contributor
    4,967
    233
    63
    Feb 3, 2010
    Racine, WI
    try opening the .pdf in photoshop?
  13. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    You nailed it!!!!
    Thank you!!!:U Rock:
  14. GAC05
    5,915
    787
    113
    Dec 27, 2005
    Guam USA
    I opened it in adobe reader.
    Right clicked on the image with the attribute inspector and copied the image to the clipboard.
    Pasted it into the open pdf in illy and it came in as a cymk bitmap 490x373 pixels.
    Looks correct but I am not sure.
    The layout is a business card and the image takes up just a small part of the layout so I think it is the correct biz card size but will not be much use in a banner or poster layout.
    wayne k
    guam usa
  15. insignia
    insignia Very Active Member
    place the .pdf in a new document, then go to (I think, I'm not at a design computer) the object menu > flatten transparency, then hit control-7 a couple times to release any clipping masks, that should allow you to break apart the file and edit it like normal.
  16. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    Same thing happened here - MikePro nailed it with his PS idea.
    Thanks again for checking it out.
  17. MikePro
    4,967
    233
    63
    Feb 3, 2010
    Racine, WI
    booyah!
    not bad for a kid that just finished a 23hr workday! (no joke)
  18. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    Tried that, but it didn't work.
    There were no clipping masks.
    But MikePros idea worked.
    Thanks for the idea insignia
  19. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    23? why not 24??? hahaha Thank you once again no go get some much needed sleep
  20. Bly
    Bly Very Active Member
    3,043
    365
    83
    Mar 9, 2004
    Sydney
    Opening the file in Reader Pro, then right clicking with the Touch Up object tool gives you the Edit option which will open the image in Photoshop.
