file not embeded in illy - what to do?
Sign_Boy
Hey all,
I'm hoping someone could help me out here.
I have an ai that's missing an image (it's not embeded) and I don't have the file, I can get it but wanted to try a workaround first.
I do however have a pdf with the image in it.
Is there anyway to open the pdf in illy and somehow preserve the image?
I'd appreciate any help on this.
:thankyou:
:supersmilie:
WildWestDesigns
Hey all,
:thankyou:
:supersmilie:
Did you try "placing" the pdf in an ai document? "Placing" instead of flat out opening seems to be a workaround that's being used lately. Give that a try if you haven't already.
Sign_Boy
Tried it, no luck. It brought it in but I couldn't break it apart.
Thanks anyway!!
Custom_Grafx
Right click on the Ai file in question, and open with acrobat pro.
If you see the image there, let me know.
Sometimes you can see it when opening it with acrobat, but when opening in Ai, it'll tell you it's missing a linked file.
If it's the former, there is a work around, as WWD mentioned.
Sign_Boy
Did it and it's there
GAC05
Quit buggin' me
can you post the pdf?
There is almost always a way to extract images from pdfs.
wayne k
guam usa
Sign_Boy
wayne k
guam usa
Not sure if the customer wants this out there.
I'll PM you in a sec.
On a side note the customer is getting me the file I need.
Now it's just a matter of trying to figure a way to do this, but I feel Mason may be right.
royster13
Drag it in and put it back together....Cut and paste it into a new document....And then rasterize the result....
GAC05
Quit buggin' me
I opened it in adobe reader.
Right clicked on the image with the attribute inspector and copied the image to the clipboard.
Pasted it into the open pdf in illy and it came in as a cymk bitmap 490x373 pixels.
Looks correct but I am not sure.
The layout is a business card and the image takes up just a small part of the layout so I think it is the correct biz card size but will not be much use in a banner or poster layout.
wayne k
guam usa
Letterbox Mike
place the .pdf in a new document, then go to (I think, I'm not at a design computer) the object menu > flatten transparency, then hit control-7 a couple times to release any clipping masks, that should allow you to break apart the file and edit it like normal.
Sign_Boy
wayne k
guam usa
wayne k
guam usa
Same thing happened here - MikePro nailed it with his PS idea.
Thanks again for checking it out.
Sign_Boy
Tried that, but it didn't work.
There were no clipping masks.
But MikePros idea worked.
Thanks for the idea insignia
Bly
Opening the file in Reader Pro, then right clicking with the Touch Up object tool gives you the Edit option which will open the image in Photoshop.
