Flexi swatch error
Discussion in 'Flexi' started by rzr2rocket, Nov 28, 2009.
  1. rzr2rocket
    rzr2rocket Member
    37
    I just bought a new computer with Windows Vista and I just bought FlexiDesigner 8 all about 2 months ago. Everything has been working fine up until 3 days ago. For whatever reason an error will pop up when I hit the button to show my swatch panel. It says...
    "An unknown failure has occurred. It is recommended that you restart the application"
    Then when I hit the "ok" button the whole flexi program will close.
    I have restarted the computer and reopened Flexi, but the same error appears.
    Is there a button I hit? Can anyone help me with this?
  2. All Signs Inc.
    All Signs Inc. Member
    42
    Welcome to Flexi!!!!
  3. encadtech
    encadtech Member
    106
    Sep 8, 2008
    Higganum CT
    I have seen Flexi get confused w/ swatches and tool settings - From the start menu - go to Preference Manager. Load the factory defaults and this should fix your issue. You will need to setup your tool bars and preferences when you get done. After you re-arrange your tools again - save this preference so that you can revert to it in the future if need be.
  4. rzr2rocket
    rzr2rocket Member
    37
    Thank you encadtech! That worked.
  5. Designer Wraps
    Designer Wraps Member
    364
    Aug 28, 2007
    NJ
    Thank you. Thank you. Thank you! Did a quick search on this topic (after pulling out my hair for an hour) and found this old post. It worked!!
  6. CS-SignSupply
    CS-SignSupply Very Active Member
    Congrats on using the Search function here!
    As for Flexi, preference files do get corrupted every once in a while... Not the only program to do so either.
  7. Sign to Go
    Sign to Go Member
    234
    Default Swatch
    And keep a file copy of a known favorite swatch table that can be copied to the swatch table in case the current working default swatch gets somehow mysteriously hosed.
    Jim
  8. Designer Wraps
    364
    Aug 28, 2007
    NJ
    Gotta luv signs101.
    Thanks guys.
  9. pure_media
    pure_media Member
    36
    hahahaha i just came back from an install and i hopped onto 101 here and read this post. I thought i'd go through and figure out the steps stated above incase I would ever need to do it....so i click on my Flexi bar at the bottom of my screen and up it pops saying.... "An unknown failure has occurred. It is recommended that you restart the application"
    I got a kick outta that....FlexiFAIL.
    Almost time to call it a week! Everyone have a great weekend!
  10. Sign Works
    Sign Works Very Active Member
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    Isn't it Flexi version 8.5 that begins to be Vista compatible?
  11. CS-SignSupply
    Correct, 8.5 was the first version officially supporting Vista
  12. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    for example?
