Flexi swatch error
rzr2rocket
I just bought a new computer with Windows Vista and I just bought FlexiDesigner 8 all about 2 months ago. Everything has been working fine up until 3 days ago. For whatever reason an error will pop up when I hit the button to show my swatch panel. It says...
"An unknown failure has occurred. It is recommended that you restart the application"
Then when I hit the "ok" button the whole flexi program will close.
I have restarted the computer and reopened Flexi, but the same error appears.
Is there a button I hit? Can anyone help me with this?
encadtech
I have seen Flexi get confused w/ swatches and tool settings - From the start menu - go to Preference Manager. Load the factory defaults and this should fix your issue. You will need to setup your tool bars and preferences when you get done. After you re-arrange your tools again - save this preference so that you can revert to it in the future if need be.
Designer Wraps
Thank you. Thank you. Thank you! Did a quick search on this topic (after pulling out my hair for an hour) and found this old post. It worked!!
CS-SignSupply
Congrats on using the Search function here!
As for Flexi, preference files do get corrupted every once in a while... Not the only program to do so either.
Sign to Go
Default Swatch
And keep a file copy of a known favorite swatch table that can be copied to the swatch table in case the current working default swatch gets somehow mysteriously hosed.
Jim
pure_media
hahahaha i just came back from an install and i hopped onto 101 here and read this post. I thought i'd go through and figure out the steps stated above incase I would ever need to do it....so i click on my Flexi bar at the bottom of my screen and up it pops saying.... "An unknown failure has occurred. It is recommended that you restart the application"
I got a kick outta that....FlexiFAIL.
Almost time to call it a week! Everyone have a great weekend!
