Compilla
Thanks for the offer, Matt! I was just seconds away from calling you when I got a reply from Randy at Mutoh! I'm back up and running now!
Thanks!
How did they fix the Issue ?
Thanks!
next time pull the chip off the old cart. put on new cart. done.
I was under the impression that once a cartridge (smart chip) is designated "empty" by the printer, the chip is flashed so it can't be used again. If that is so, how can the old chip work on the new cartridge?
btw ,i have exp. in installing Vj1604 ,and i saw what it does(problems with ink during installation)
solving : charge flg = Mm 2
: change chips on cart.
Can you better explain that ??
PLZ!!!
mm2 = maintenance mode 2
cards on carrtriges
May be my post that suggest for 3rd party ink pushed their button?
We really need to support 3rd party ink mfg to spur competition. Mutoh's smart chip is too smart for their own good with many return of good cartridges.
At $65 per 220ml, it is over 1K per gallon. It is really more profitable selling inks than printer. We easily spend more ink money than the printer itself in one year.
There's big litigation on the desktop printer end going on due to this "factory ink" bullshit they try to pull. Legally, they have to make their units to use third-party inks as long as they are up to a certain standard.
Making the chips self-flashing is part of the illegal moves that printer companies do to keep us from using other inks.... according to anti-trust legislation, it's against the law.
Back on topic, so I'd have to contact Mutoh directly to get a new chip for my 25% full cartridge? At 1K a gallon, I'm not wasting it, that's for sure!!!
When reporting smart card issues:
Please provide your printer serial number and the situation in which the chips failed in your call to your dealer (and or Mutoh) along with your contact information. Every issue is being tracked..
Randy,
Is this a Valuejet only problem? Because just this week the same thing happened to me on My Falcon II Outdoor. I was able to play with the cartridges enough and got it back up and running. That has never happened before on this printer. Is it something I should be concerned about from now on?
