Help w vinyl cutting
twocents
I only have the manual that comes with the CD. I have managed to be able to get the sizes correct and cut shapes and freehand letters. I can not get it to cut text though. Man my head is spinning
twocents
When I click the black area I can see the image but as soon as I let go it turns black again.
TyrantDesigner
Art! Hot and fresh.
you need to learn how to make compound vectors and learn how order of objects affects an item.
You need a tutorial or 4. Learn the basics of corel, it will save you from asking about that issue right there.
twocents
OK I got this thing cutting, It cut text a few times than I couldnt get it to anymore. I could only cut freehand which worked fine with coreldrawx5. Now I cant get it to do anything again, it's like I am going backwards here. Going nuts and ready to break this thing. I uninstalled everything because I kept getting errors: USB currently in use, wait 10 secs and try again code=1004 when i try to open the controller. Or when I send it from corel I get the error now outputting a job please wait to send the next job until the current job is completed. When I reinstalled it the same errors come up. Just about sick with this now.
GRAPHTEC
#1 you should call Graphtec tech support, they get you up and running really fast- they wont teach you everything about your plotter but they will mention the basics. My best advise is to forget about cutting from the RM software and the controller- since you have corel Draw Graphtec has a plug in software called Cutting Master 2- you can downld it from their site and its free:
www.graphtecamerica.com/support
this software will allow you to cut directly out of Corel Draw.
Tel
I honestly think the problem hear is operator errors, no offence meant but do you understand the difference between a vector and Bitmap images, if your cutter as you say appears to be looking for registration marks that's because it's being told there is a print on the vinyl with registration marks and usually this would have a contour line around it which is cut leaving one with a sticker.
vectors are mathematical if you stretch a vector it gets bigger with no distortion but a bitmap will pixellate, plotters only cut vectors, you need to learn more I think it's difficult through this medium if you could find someone to sit down with you and the machine even at a price I think it would be worth it if it gets your business up and running.
