ColesCreations
I have been getting a few inquiries how to reset the date in JV3's, to enable using up all the ink.
Many users are frustrated by having to replace their cartridges before empty, due to date expiration. This is not necessary.
Also, we always "add 30 cc" when printer says "near end". We verify by weighing the cartridge with an electronic scale from an automotive paint shop. If it has 430 grams at the time of "near end", we add 30. This corresponds to around 8%, and is significant. An empty cartridge weighs around 390 grams (This is as low as I've seen one, and will suck air). I'd be careful going close to 400 grams if running large prints though! Don't leave town with "near end", as printer does not do its regular cleaning cycles, and it will clog.
During the 2 years we have had our JV3, we have used SS2 OEM ink, most cartridges have been expired, some even when we got them, many of them more than a year out of date. We have not had any problems with plugged heads, all 4 (8) heads still have perfect test prints, on the original heads.
For you JV33/JV5 users, I would recommend uniting and demand from Mimaki that they release the code to reset the date, when the printer is out of warranty. Tell MImaki to do it, if not, the next one will be an Epson... (Damned nice solvent printer out now...)
Here's how to reset the date to factory default:
1. Power down the printer and computer. Unplug power cord.
2. Unplug firewire.
3. Remove cover on back of printer, right side (Behind firewire plug)
4. Carefully remove firewire card.
5. Behind firewire card you will find the battery. Take it out, leave it out for a few minutes, then put it back in.
6. Put everything back together, and power back up. Your date should now say 010105. Some settings will have changed back to factory default, such as feed etc, but nothing major will change.
PM me if you have questions, I check my mail pretty much every day.
2. Unplug firewire.
