This is really helpful. Thank you. One question though, doesn't the pass count mean more ink? I understand how this slows the drying time down, but doesn't it compound the issue with more ink? I have heard inter delay pass can also help, but have had no luck finding that on the menu either.
tHanks again Effective Cause!
With latex the higher pass count
does not equal more ink. To increase or decrease your ink you need to use the ink density.
With heavy saturated areas not drying....
increase your heat, the material might become deformed in the 'curing area' a little deformation is ok but a lot means that your heat is too high.
Increase the number of passes, this will give you more 'dwell time' in the curing area.
Increase/decrease ink density, this will adjust the amount of ink that the printer lays down.
So if you can try adjusting any or all three of these.
Watch some videos on how to adjust these if your unsure how. HP has a profile setup feature where you can set up a material specific profile and adjust all of these and more to help achieve a constant product. I suggest you look at using it as it will get you better acquainted with your machine and the setting.
