To go along with the thought that maybe they are not cured properly, Are the temp settings correct for the material you are using?
All prints that come out of the HP Latex Series of printers are intended to be dry, cured and ready to laminate or finish immediately without any need to wait. Latex does not air dry - it is cured within the printer. If the prints are oily, wet or not cured - something is wrong. Could be the profile which would include optimizer levels, could be settings, could be RIP, could be mechanical - but bottom line, sounds like something is not right. You mention talking to your supplier - which is always a good first step, but if they cannot help you, your 360 are covered by a HP Warranty. I tried to PM you, but since I am not even a Sophomore in HS yet apparently, I cannot do this. You can reach me at latex@hp.com - and I can assist you with getting support. Thank you for your support of HP Latex printing.
Pretty sure we are printing on fresh material. We go through several rolls per week so they are new to us, hopefully they are new from the local distributor. Haven't noticed any oily appearance, but will keep looking. frustrating is right!
Good thought. We are running a Seal 54 with heat assist. We lam most of our PS vinyl at 80% pressure. We've tried it with and without heat assist, same results either way. It has to be something with the inks is my best guest.
