Not to get in to this, or interrupt this thread, but with an opinion like that it's either you've not used one, or you sell against it. I've got a fleet of them and they work great. They're much better than other machines out there in this class. I'd gladly take one any day over the Rolands we've had, and those were considerably more expensive in start-up costs, maintenance costs, and ink costs, and the print from the Roland XJ-740s was not as good.If the machine was that solid it wouldnt be such a free for all for the manuals.
I got it too, even though i dont have this printer but may get one in the future.
It's good to have it just in case.
If the machine was that solid it wouldn't be such a free for all for the manuals.
damn dude. did a hp printer fall on your weiner? did the mrs. make sweet sweet monkey love to one whilst you were out of town?
we want the manual so we can have it as a reference for our printers. if anything alll the response shows how many people have/want the printers.
i have them for my mutohs as well. does that mean mutoh suck too in your mind?
Our old Colorspan Displaymaker was that way, had a 386 or earlier cpu if I had to guess. Cheaper to take something off the shelf then designing from scratch.I noticed the main board in there is basically just a re-purposed PC motherboard. They didn't even remove the PCI slots, or the PS/2 ports on the side. The only markings I can see, where the model would normally be, are "JESULIN +LF". Might be an OEM model to keep snoops like me from replacing it with an aftermarket part. Anyone have any other info, like other model markings, on the main boards of their HPs?
Crazy! Cheap as it is, I still find it odd to find such high-end equipment mish-mashed like that. Reminds me of the old T-Jet dtg printers, which were basically Epson 2000's with an art deco toaster casing attached.
I wonder if you could just interchange it with a better motherboard of the same spec? So long as the HD is still attached, it should be able to load the parameters just fine. If they've gone as far as just cannibalizing PC parts, I'm willing to bet they just have a stock BIOS running on that thing too. Someone plug their monitor into it so we can find out!
(I assume NO responsibility if you do this and bad things happen, as they most likely will)
