HP L330 DNS settings
Dennis422
Looking to fix an issue with my HP L330 not connecting to the internet.
It seems that DNS settings were messed up. I am able to send stuff to be printed, network connection is OK. Only issue is that I can not connect to the internet do download profiles and firmware update.
Anyone had or has the same issue?
Creighton
It seems that DND settings were messed up. I am able to send stuff to be printed, network connection is OK. Only issue is that I can not connect to the internet do download profiles and firmware update.
You have it receiving a DHCP address from your router so the DNS populates automatically, or did you manually assign an IP?
FrankW
Set the Printer to DHCP for a moment. The printer will poll the correct data. Set it back to Manual, the printer will remember the polled data. Set the right manual IP-Adress again.
dypinc
Since your not connecting your printer directly to the internet your DNS server setting in the printer should be your Routers address. Let your Router handle outside DNS server addresses.
Dennis422
Hi everyone. Thanks for replies.
I tries 8.8.8.8 and 8.8.4.4 combo, tried 1.1.1.1 and 1.0.0.1 combo, got the router numbers, reset to factory......
Nothing worked.
Will have to try something else.
Nothing worked.
I doubt it's the DNS settings. Usually when you don't input DNS settings it just defaults to the router's default DNS. Are you able to print to the printer? If not, I would say you have a general network issue.
bannertime
If you can print, in a pinch you can send profiles to the printer from your browser and some RIPs.
What's your network setup like? What's the setup between the computer, router, and L330?
Dennis422
Yes, I can print.
I have my printer connected to the router, and router to the internet and a computer.
It is printing fine but for some reason it will not connect to the internet.
Joe House
Sign Equipment Technician
I've had problems setting up the printer if the clock is not set to the correct time. Check your date and time settings.
AF
Restart the router, restart the printer, disconnect allmother hardware, double check settings and test. Make sure cables are the correct type and connected to the correct ports.
