I appear to be having two different issues here (or maybe they're related?). The first image shows some pink/yellow ink, which I am assuming is a bad printhead malfunction? Never seen this happen before. The second image is showing some off-color banding starting only from the side that slowly fades out in different sizes. It's inconsistent when it wants to appear, but when it does, it looks very noticeable. Any tips on how to fix this issue?
We were dealing with a similar problem last month. Lesson learned (again), don't print huge panels of neutral colors on the latex. We had to do a color change on a vehicle and I cannot tell you how many times that had to reprint panels because of color shifting, banding and other inconsistencies.
Any time we start to see banding like that, one of the first things we do is check the print heads. Issue a nozzle check to see if anything is out. Often times we noticed in those lighter colors it tends to be an issue with the light cyan/light magenta print head. So if that one is 3-4k ml of ink fired I'll generally change it out.
The other thing we do is force drop detection in the maintenance menu. This will check for blockages and can be done before doing the nozzle check if you want. I find that it is a quick way to narrow down the issue without having to clean all the print heads. It would tell you which colors are blocked and that way you can target those print heads specifically or on the other hand you can skip the cleaning altogether if your values come back as 0's or relatively low.
If you haven't done this before its under the service menu. PRESS 3174 to enter service mode and go to the (1.5) scan axis menu -> (1.5.1) force drop detection
