To the OP, we have a digital printer in shop. I have printed out a large PMS color chart and laminated it. The colors do not always match up perfectly with the color swatch book but rarely does that matter with our clients, (local sign buyers). What it does do is give me the ability to allow them (or me) to pick out a color from the chart and know that that color will look exactly like the swatch that was picked. Perhaps your MM could provide you with something similar for a reasonable fee.
Did you create this chart from scratch?
Not wanting in a fuss, but everything that Bob has said so far is the way that I operate, and have little problems with my raster image colors and my RGB colors print much truer to the screen than my CMYK's. Not saying there isn't another road that leads to the same place though.
jbennett
...Apparently, everyone else in the world has magically calibrated monitors whose screen color exactly matches their printers (in house and out.)
You're obsessed with monitors. Regardless of how carefully you've calibrated, or not, what shows up on a monitor is meaningless, it's what comes out of the printer that's the truth. The whole truth and nothing but the truth.
It just so happens that uncompressed RGB jpg, et al,is as close to a universal format as exists at this time. Not perfect but acceptable. An RGB jpg shows with reasonable accuracy on any decent monitor. Moreover, on most any properly set up system, it reproduces acceptably true.
Perhaps this is because virtually all RIPs move into and work out of LAB space. I can't say for certain since I've never taken apart a modern RIP, I can only extrapolate from previous experience.
I realize that this seems in direct contradiction to what you learned in some school somewhere. Not surprising, as the map is not the territory, theory is not reality. Except perhaps for some of the more esoteric branches of theoretical physics. Know the territory and the map becomes irrelevant.
digitalprinter=CMYK. i tried to order RGB inks for my mimaki. I still hear the laughter.
i have been doing graphic design since 1987. Even those AB dick 360 printers used CYMK.
Fast forward to present. CMYK is still the weapon of choice. i send, outsource, proof, print, EVERYTHING IN CMYK. RGB is for monitor viewing only. (That is of course, if you bought a calibrator for it.)
Don't get me started on that crap.
I printed my (jv33) own Pantone "process to CYMK" color chart and this is what i get my own customers to pick colors from.
Long live Big Bird.
And the reason I'm so "obsessed" with monitor calibration is because you can't get repeatable results based on what YOUR monitor looks like alone. Period. If you could, then Pantone, HEX, and any other color matching system would be obsolete. End of story. You are suggesting that everyone design and choose colors based on what it looks like on their monitors. And that is just plain bad advice.
Again, your reading comprehension skills seem desperately limited. Which part of "The printer is the truth" do you not comprehend?
I do not and never have suggested that anyone rely on what shows up on a monitor. Just the opposite. The printer is the truth ergo what shows up on a monitor is the map and not the territory. What shows up on a monitor merely is suggestive, what comes out of the print is definitive.
Here in this shop the printing tackle is well understood and when designs are assembled what appears on a monitor is understood to only be true for size and shape. Color on a monitor may or may not represent the truth that will emerge from the printer.
I did remark that an RBG bitmap such as a jpg file usually appears on most media reasonably true. I have no necessary and sufficient conditions as to why this should be so, merely a great deal of empirical evidence confirming this bit of pragmatism. Since it works I've never been moved to examine why it works.
