rootyb
(I've been a lurker for quite a while, and decided to finally create an account to do some research for a project I'm working on. Searching didn't turn up much on this, so I figured I'd just ask)
I'm looking for recommendations on making printed "stickers" (skins, really) for the front of the Oculus Rift VR headset. The headset, however, has near-infrared LEDs positioned across (underneath) its surface for positional tracking. Blocking this light would cause problems.
I can see a few options, material-wise:
1) Leave holes in the design where the LEDs are. This is my least-favorite idea, as it would mostly look dumb, but it would also be certain to not cause issues with the LED detection.
2) Perforated window vinyl. This seems like a fairly solid choice, though the designs would be viewed up-close, and the holes in perf vinyl are usually unnoticeable at a distance, but very obvious up-close. It seems unlikely that the perforated vinyl would interfere significantly with the LED detection.
3) Translucent, backlit-sign vinyl. This might be a good option (and would certainly look the best, I think), but would take some testing to whether the vinyl + ink block enough of the infrared light to cause detection problems.
4) Clear vinyl. This seems like an alright option, but having no experience with it, I'm assuming that a white undercoat would go below the ink, and I'm not sure how IR-translucent the white undercoat would be.
I'd also like the skins to be fairly removable (the surface in question is a matte-finish plastic. Smooth, but not glossy), as people probably won't be too keen to put permanent skins on their $600 headset.
I *think* that things that let visible light through will *usually* let enough IR/Near-IR through for my needs, but obviously, not always. I'm sure that I'll need to do a fair bit of testing to see what works and what doesn't, but before I go out and stock up on tons of different samples (if I can even get appropriate samples), I figured I'd check with the fount of knowledge that is Signs101.
FYI: Experience-wise, I've done some decal work, and have a buddy that does signs/decals. He has an epson (iirc) 20" printer whose model number escapes me right now. He hasn't done anything with backlit or perf vinyl, though, and nothing that depends on IR translucency.
Thanks for any insight or experience you can share!
