This- or, reverse print on clear with white (if your printer supports it) and laminate/install as normal- on the inside, of course.We reverse print on clear vinyl (you can use laminate if you don't carry clear vinyl) and laminate with white vinyl. The process you are suggesting might not look as good as you are hoping. Especially if the adhesive interacts with the print at all.
I am to install a printed decal on the inside of a window facing out. I am printing on polypropelene and applying a clear double sided adhesive to install. Is there another way for it to be done? Any guidance is apperciated.
