Laminator Help
TumwaterTom
chrisphilipps
More than likely it is what Royal Sovereign called the Frequency Generator. It is a common fail part on the Sigmonts. It should be located in the area that I have circled in the attached image.
  • Frequency Generator - Generations.pdf
Geneva Olson
Expert Storyteller
your emergency stop button is depressed. pull up on it. the beeping will stop and you will be back in business.
TMPSigns
The button is not pressed and it is not beeping. Believe me this was the first thing I checked. I have been in the sign industry for 20 plus years.
Geneva Olson
Expert Storyteller
oh damn. i misread what you typed. I actually got a perfectly good royal sovereign laminator for free because the stop button was pushed and someone didn't know how to stop the beeping.
Joseph44708
I Drink And I Know Things
Check that the front table plate is in correctly, if not it won't run. There is a small safety switch that is activated when table is inserted correctly.
