+1 for the GFP
Had mine for about a month now and it's been flawless.
Did look into the US Tech brands, but didn't feel comfortable when I called them to ask a couple of questions. They also never called back with any answers.
Mine does have heat assist. Have used it, and it stops the slivering. Although, it seems to go away by itself if you don't use heat. So, I'm not sure if heat assist is worth the expense. I paid about 7500. and it included shipping and on site setup. I also got 1 year on-site service, but this had to be negotiated
This machine does a great job on mounting material to a board. You can adjust the roller pressure for the thickness of the board. I had a Ledco before this and the pressure couldn't be changed. (Full pressure all the time) Problem was if I mounted to Coroplast, it would cause bubbles all along the flutted sections. The US Tech machine has no adjustment and I think you will have the same problem as the Ledco
