Hi all, Im certain that I have caused this problem myself, I cant seem to let something be until its perfect....and I often make things worse.
Everything was running ok, but I wanted to align the print heads perfectly, so I started making adjustments ect ect.
Somewhere along the line I stopped getting black to print, and eventually found that the print head was leaking air somewhere, I pulled the print head out and tried putting it back in and pulling ink through the lines a couple times, no luck. Actual print head was leaking air (Explains the ink on the print head I noticed at first). Then, I try one more time, and I got hit with the "head overcharged 075" code...everytime I tried to do a nozzle check.
I put in an old print head and the problem seemed fixed, so I started a test print and half way through I got the same message.
I am running around in circles here, and I need some major help before I fry something over here.
Is there a way to pinpoint what is causing the error?
Thanks again to everyone, you all are always so helpful and nice.
THanks, James
THanks, James
