Malware Popup
Discussion in 'Computer Hardware' started by Accelerated Graphics, Apr 3, 2008.
  1. Accelerated Graphics
    Accelerated Graphics Active Member
    887
    1
    18
    Jan 11, 2005
    Burleson
    Afer turning on my comptuer yesterday I keep getting a "Malware" popup says something about a trojan virus and i need to check for latest spyware. I ran Mcafee and it didn't find anything. Anyone have this happen, It also changes my background on my screen when I start the computer..
  2. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
  3. Mikeifg
    Mikeifg Active Member
    765
    Jun 6, 2007
    Heartland
    Same thing happened and I had to do a system restore and it fixed the problem.
  4. dakotasignwerks
    dakotasignwerks Member
    133
    1
    18
    Feb 1, 2008
    north dakota
    we just had our computer replaced from one of them bad boys. took out the hard drive i guess from what the tech said. dunno just know how to operate it.
  5. cOrKinSA
    cOrKinSA Very Active Member
    2,242
    2
    Work stays at work and Porn stay at home!
    :Big Laugh
  6. Shovelhead
    10,882
    16
    There's the problem ..porn and crack sites.
  7. Rhino
    Rhino Active Member
    535
    1
    There must have been something else wrong with your system. I've been in technology a long time and I've never seen software (virus) effect hardware.
    Them malwares and spywares are nasty!!
  8. os101king
    os101king Active Member
    Ccleaner and AVG anti-virus. BOTH FREE, dump McNortFee immediately. It's useless and a resource hog. buy a copy of Webroot's Spysweeper, but do not set it to run in the background. let AVG update & check daily, use Ccleaner every other day and run Spysweeper weekly. I do HUGE amounts of "suspect" browsing and downloading, and have not had a problem in 5 years using the same exact programs.
  9. cOrKinSA
    2,242
    2
  10. choucove
    choucove Active Member
    809
    Same here, I have ever only heard of one virus that's capable of truly affecting and destroying hardware on a level of having to have the computer replaced. It was an old BIOS bug that tampered with the CPU timing, effectively overclocking it until it burned out.
    Rick, did you ever find out the name of the malware affecting your system? If you were able to remove it from your system, what tools or software did you use to do so?
  11. Idea Design
    Idea Design Very Active Member
    1,019
    2
    38
    Jul 12, 2005
    Some people believe that an installed program will not always detect threats based on the way the virus is written. Online scans are sometimes better, like this one:
    http://housecall.trendmicro.com/
  12. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    Lately, popups are usually smitfraud.. this one comes in via email cads. Big problem recently.
    It s not stopped bye the more popular anti virus softs. AVG will notify you of a problem but not sto[p it all either. A good firewall may alert you and if you are quick to see it you can stop its downloading of its payload.
  13. SignTech
    SignTech Guest
    smitfraud VIRUS ........... I HAVE IT / HAD IT
    I tried everything imaginable it will mess your system up.
    THE ONLY thing that worked for me was Kaspersky was worth every penny. However it never fixed the color change under my icons on the background.
    No other software touched it including AVG.
    Try everyones reccomednations but I am confident Kaspersky will work ...... get the trial version first. The virus you have is nasty, not even skilled so called Techies could touch it! I had one of the best IT guys on my maching with his fancy probes and USB plug ins ............. NOTHING happening.
    UPDATE: I had the exact same symptoms ... I was just listening to music on a reputable site. NO PORN nothing ..........
  14. Techman
    8,520
    8
    38
    Jun 24, 2003
    michigan
    If a real techy cannot remove a smitfraud then he is lame.
    If this is true then he is more than lame..
    I have helped several here on this bb and also repaired over a dozen machine locally. It is not difficult if the techie is competent.
    http://www.signs101.com/forums/showthread.php?t=30347&highlight=smitfraud
    Kaspersky is not the answer. Anti virus software is not the answer.
    It takes a specific set of steps and a specific remover, and some manually deleting of files to get it all.. Believe me, it is still there, the messed up icons reveals that fact.. It will return first chance it gets.
  15. Accelerated Graphics
    887
    1
    18
    Jan 11, 2005
    Burleson
    Well techman, I'm buying the beer and dinner if you showup to fix it...
  16. Accelerated Graphics
    887
    1
    18
    Jan 11, 2005
    Burleson
    Well after 2 days of watching the popups and an email from techman, my popups seem to have been fixed.. Thanks Techman....
